Noticed that the extreme temp rule is a bit off.
For example, yesterday’s (sun) temps were forecast for 48/24. (the 24° low being 9pm Sun through 9am Mon morning). So the extreme temp rule kicks in Saturday evening when the actual overnight temps are in the 30°- 40° range (well above extreme temps), and remains in effect throughout the day till yesterday (Sun) evening (where day time temps were near 50°).
Then yesterday (Sun) evening, (just prior to the actual overnight Sun/Mon extreme temp of 24°, that it was supposed to be offset for), the tstat turns off the extreme temp rule, and returns to normal set point.
The rule is practically useless.
e.g., extreme temp is set for below 20°, Tuesday forecast is “36/18” 9pm Tues/9am Wed overnight is forecast for 18°, so extreme temp rule kicks in on Monday evening, and turns off Tuesday evening (which is prior to forecasted Tues/Wed extreme overnight low).
The problem is, that the algorithm (or whatever ADC is using) is not taking into account the following days weather for the rules is actually spanning the two following days as the low is from the following day at 9pm to the day after that at 9am.
It apparently is only taking into account the hours between 9pm - 11:59pm, when the forecasted “low” is actually occurring early the following morning.
