I’ve read other threads on this topic so I think I understand what is expected of me. My 1 year extension with GHS expires at the end of the month so I’ve sent them in writing a request to move to month to month renewal. That will give me the flexibility to leave them them so want.
I have a Qolsys OG panel and an Alarm.com account (their equivalent of Gold) along with two thermostats, two MyQ garage door sensors, a ton of lights switches, outlets and wall worts connected via Zwave to the Qolsys panel and controlled by alarm.com.
When I choose to leave GHS and that’s officially done, I should be able to sign up with you, re-register my Qolsys control module with you and create a new alarm.com account. I of course would choose which monitoring services I want. With that I should be good to go, correct? I expect that since the system already works with alarm.com and has a cellular connection, all that should be compatible with your service. That assumes I keep my existing equipment.
I’m also strongly thinking about upgrading to the Q2 unit, swapping out my thermostats for the alarm.com thermostats (one upstairs and one downstairs)… and adding an extra remote thermostat to each floor… as well as adding a Skybell door bell plus the $3/mo Skybell service. Getting the Q2 control unit, the alarm.com thermostats and the Skybell door bell can all be done independent of each other, right? If I choose to upgrade to the Q2 control module, I’ll get 6 months of monitoring included for a value of just around $170, correct? Is that deal only for new customers?
I’ve installed and programmed almost all of the Zwave devices in the house so moving over should be a piece of cake for me.
