sergioadh
(Sergio)
1
I’m installing a couple of SMKT8-345 units. Is the install process the same as the SMKT2-345?
What would the equipment code be for these units?
Smoke - 09 - 24 Hour Fire - Loop 1
High Heat - 09 - 24 Hour Fire - Loop 2
Freeze - 08 - 24 Auxiliary Alarm - Loop 3
Does this look correct?
tyler
(Tyler)
3
Yes, those programming choices are correct. The SMKT8 shares the same programming as the SMKT 2 and 3.
1058 2GIG Smoke Detector would be the Equipment Code.
2GIG-SMKTx-345 programming can be found here.
