2GIG Go!Control Panel Sensor Programming Guide
2GIG-SMKT3-345 Smoke/Heat/Freeze Detector, 2GIG-SMKT8-345 Smoke/Heat/Freeze Detector
Smoke:
  • RF Sensor Type: (9) 24 Hour Fire
  • RF Sensor Equipment Code: (1058) 2GIG Smoke Detector
  • RF Sensor Serial Number: Shift - Learn - Tamper Sensor
  • RF Sensor Equipment Age: New
  • RF Sensor Loop Number: 1
  • RF Sensor Voice Descriptor: Smoke Detector
  • RF Sensor Reports: Enabled
  • RF Sensor Supervised: Enabled
  • RF Sensor Chime: As desired, can be changed out of programming
Heat:
  • RF Sensor Loop Number: 2
  • RF Sensor Voice Descriptor: Heat Detector
Freeze:
  • RF Sensor Type: (8) 24 Hour Auxiliary
  • RF Sensor Equipment Type: (6) Freeze
  • RF Sensor Loop Number: 3
  • RF Sensor Dialer Delay: Disabled
  • RF Sensor Voice Descriptor: Freeze Detector
The following video shows a walkthrough of adding this sensor to your alarm panel.
