Hi Jason,
No the ST node is still showing on the IQ Panel 2. I just lose status and control of my Linear garage door opener through ST. I can still control the garage door through the panel and Alarm.com
I only have 2 z-wave devices outside of ST and the IQ Panel2. A GE outdoor light switch module that functions as the repeater to reach our garage and the Linear.
I’m always able to control the GE light switch from ST, the IQ Panel 2 and alarm.com. For some reason after time I lose the garage door opener through ST. Trying to repair the network doesn’t work.
I just went through the whole process again Sunday night. I excluded ST from the panel and then re-added it. I get the following message:
“You are about to include a z-wave compatible device that is not promoted by Qolsys for use in this application. While the device should work as expected the device features may or may not be support by the Qolsys”
I was able to control both the GE light and the door from ST, the panel and from alarm.com (web or app). However this functionality was shortlived and I lose ST. Should this setup work with ST, the IQ Panel 2 and alarm.com all able to control the the garage door opener? It’s possible I just have a communication issue between all the devices given distances between devices. Just trying to eliminate possibilities.
