Smart Water Valve+Meter ADC-SWM150 - Installation Guide
Service package requirements
The Smart Water Valve+Meter (ADC-SWM150) requires both the Water Management and Water Management Plus service package add-ons to support advanced flow monitoring features such as Unexpected Water Activity alerts, Water Flow Shut-off rules, and water consumption display.
Through Surety, Water Management is included in the Surety Home and Surety Complete service plans. However, you will need the Water Management Plus add on as well. Water Management Plus add-on is an additional $2 /mo and is enabled via the System Manager section of your Surety login.
Installation precautions
  • Adhere to all relevant local codes and ordinances as they pertain to the Smart Water Valve+Meter. You are required to consult local plumbing codes and have appropriate licensing for the installation of this device.
  • Water shutoff valves and leak detection devices should never be installed on a fire suppression system. If a fire suppression system is present, ensure that the Smart Water Valve+Meter is installed downstream of the branch leading to the fire suppression system.
  • Never insert fingers or any other item into the valve. Inserting objects into the valve may result in damage or injury.
  • The Smart Water Valve+Meter should only be powered using the supplied power adapter (supports mains voltage: 100-240 VAC ~50/60 Hz).
  • Take note of the Device Specific Key (DSK) and QR code located on the back of the control unit and product packaging. These are used to quickly and securely add the device to a Z-Wave network compatible with Z-Wave Security 2 (S2) and/or SmartStart.
Important : Do not apply power to the Smart Water Valve+Meter until the unit is fully assembled.
In the box
Pipe sizing
For ADC-SWM150
Pipe size 1” - thread type MNPT
For ADC-SWM150-EU
Pipe size ¾” - thread type MBSPP
Additional parts requirements
Installation of the Smart Water Valve+Meter requires additional fittings to connect the ends of the valve+meter to the pipe. The type of fittings needed depends on the pipe material, pipe size, threading type, industry standards, and applicable plumbing codes. The maximum compatible pipe size is 1.25" (3.175 cm).
LEDs and Buttons
LEDs
(1) Network
  • On: Added to a Z-Wave network
  • Blinking: In Add mode
  • Off: Not added to a Z-Wave network
(2) Valve open
  • On: Open
  • Blinking: Opening
  • Off: Closing or closed
(3) Valve closed
  • On: Closed
  • Blinking: Closing
  • Off: Opening or open
(4) Flow
  • On: Water is flowing
  • Blinking: Hardware diagnostic code - see Troubleshooting
  • Off: Water is not flowing
(5) Alert
  • Off: No active events
  • Blinking: Flow/temperature event active - log into the customer account for more details
All LEDs off
If all LEDs are off, the device has no power.
Buttons
(6) Network
Used for Z-Wave Add/Delete mode. This button is also used to factory reset the device.
(7) Open
Opens the valve.
(8) Close
Closes the valve.
Installation location
Note : Water shutoff valves and leak detection devices should never be installed on a fire suppression system. If a fire suppression system is present, ensure the Smart Water Valve+Meter is installed downstream of the branch leading to the fire suppression system.
The Smart Water Valve+Meter must be installed:
  • In a dry, indoor location.
  • Downstream from the main shutoff valve and, if present, the pressure reducing valve.
  • As close to the main shut-off valve as possible. The Smart Water Valve+Meter only monitors water activity downstream of the device.
  • On a straight run of pipe approximately 14 inches (35 cm) long. The Smart Water Valve+Meter can be installed in smaller spaces by rerouting the plumbing.
  • In compliance with all local plumbing and electrical codes.
  • Within 20 feet of a wall outlet. It is recommended to use an outlet with a ground fault circuit interrupter (GFCI).
  • On water main distribution pipes 1 inch or less (ADC-SWM150) or ¾ inch or less (ADCSWM150-EU). For installation on larger pipe diameters, please review local plumbing codes, water demand, and hydraulic performance to ensure varying pipe sizes are compatible.
  • With the control unit located above the valve+meter. Use drip loops wherever possible to avoid damaging the electronics in the event of a leak.
  • So that it is easily visible and accessible.
Note : The Smart Water Valve+Meter features a backflow preventer. Ensure that there is adequate distance between the Smart Water Valve+Meter and the home’s hot water heater to allow for the expansion caused by the hot water heater. Additionally, consider installing an expansion tank downstream of the Smart Water Valve+Meter. It is not recommended to install the Smart Water Valve+Meter directly on the water heater supply line.
Installing the Smart Water Valve+Meter near a water heater
In some locations, the Smart Water Valve+Meter will need to be installed in close proximity to the water heater.
Because water expands as it is heated, if the meter is installed within several feet of the water heater, the pressure could build up and lead to the Temperature and Pressure valve on the water heater releasing to reduce the pressure.
This is not desired, so if there is no way to increase the distance between the water heater and the meter, it is advised to install an expansion tank on the inlet side of the water heater. This will allow the water to expand without creating a pressure spike that could damage the plumbing system. Expansion tanks should only be installed by a licensed professional.
Installation
  1. Shut off the water supply line and drain all water from the plumbing system.
  2. Install the valve+meter in the water supply line using the appropriate fittings.
Important: Ensure that the device is installed in the correct orientation. An arrow embossed on the valve+meter indicates the correct direction of water flow.
Note: If soldering fittings or adapters, use caution to ensure that the valve+meter is not damaged by excess heat. Remove the valve+meter from the fittings prior to soldering, if possible.
  1. After installing the valve+meter, slowly turn on the main water supply and ensure there are no leaks originating from the valve+meter, connections, or surrounding pipes.
  2. Connect the cable harness to the valve+meter.
    A. Connect the black VALVE cable to the actuator and tighten the screw connector to ensure a secure connection.
B. Connect the green GROUND cable to the ground cable connection on the valve+meter.
C. Connect the black HIGH cable to the high flow sensor and ensure that the tabs on the connector are fully engaged on the flow sensor.
D. Connect the red LOW cable to the low flow sensor and tighten the screw connector to ensure a secure connection.
Note : The blue AUX cable is reserved for future use. It is recommended to leave this cable disconnected.
5. Install the enclosure (space permitting).
A. Attach SIDE A of the enclosure onto the valve+meter by clipping the valve+meter into the clips.
B. Secure the cable harness by inserting it into the cable harness holder on SIDE A of the enclosure. Ensure that all cables are inside the enclosure and connected properly.
C. Attach SIDE B of the enclosure to SIDE A. When properly aligned, the two sides of the enclosure snap together using the integrated magnetic clasps.
  1. Use the included wall bracket and anchors (if applicable) to mount the control unit above the valve+meter, making sure the LEDs and buttons are visible and easily accessible.
  2. Connect the power supply to the power supply connection on the control unit. Tighten the lock screw to secure the connection.
  3. Plug the power supply into the nearest nonswitched wall outlet. Verify that the Smart Water Valve+Meter is powered by checking that either the Valve Open or Valve Closed LED is illuminated on the control unit. If no LEDs are illuminated, try a different power outlet.
  4. Test the Smart Water Valve+Meter to make sure it opens, closes, and detects flow
  5. Add the Smart Water Valve+Meter to the network
To test the Smart Water Valve+Meter:
  1. Fully open a tap or faucet downstream of the Smart Water Valve+Meter.
  2. Press the Close button and wait for the Valve Closed LED to turn solid.
  3. Check that the valve has closed by verifying that no water is flowing from the fixture opened in step 1.
  4. Verify that the Flow LED is not illuminated, indicating water has stopped flowing.
  5. Press the Open button and wait for the Valve Open LED to turn solid.
  6. Check that the valve has opened by verifying that water is flowing from the fixture opened in step 1.
  7. Verify that the Flow LED is illuminated when water is flowing.
  8. Close the tap or faucet opened in step 1.
  9. Verify that the Flow LED is not illuminated, indicating water has stopped flowing.
To add the Smart Water Valve+Meter to the Z-Wave network:
Important: For best results, it is recommended to bring the Z-Wave controller into the area where the Smart Water Valve+Meter is installed during enrollment.
As a SmartStart device:
It is recommended to enroll this device as a SmartStart device to eliminate the need to put Z-Wave controllers into Add Mode or to trigger devices (as is the case when enrolling non-SmartStart S2 devices).
As an S2 device:
If the Z-Wave controller is not SmartStart-compatible, it is recommended to enroll this device as an S2 device for enhanced security and encryption features.
As an S0 device:
  1. Put the Z-Wave controller into add mode.
  2. Press the Network button on the side of the Smart Water Valve+Meter control unit to begin the Add process. The Network LED on the control unit will begin flashing.
  3. After the Smart Water Valve is successfully added, the network light on the Smart Water Valve will turn solid. If the Network LED is not illuminated after the add process, repeat steps 1 and 2.
