Alarm.com has added support for two new Shelly Wave devices that take advantage of the recently released multi-channel Z-Wave support.
Shelly Wave Pro Dimmer 2PM
This is a two-channel, DIN-rail smart dimmer with built-in power metering. It can control up to two independent lighting loads from a single device, with full dimming capability for each. It features 800 Series Z-Wave technology with Z-Wave Plus, SmartStart, and S2 security support.
Shelly Wave 2PM
This is a compact, two-channel Z-Wave smart switch that provides independent on/off control of two electrical devices from a single module. It includes real-time power monitoring for each load individually as well as total combined energy consumption. It’s compatible with standard switches and push buttons, making it a good fit for lighting, fans, and other appliances.
Both devices are fully integrated with the Alarm.com app and website — each channel appears as its own controllable device, so the experience is the same as any other smart light or switch. The two-channel design means fewer devices to install and lower hardware costs when you need to control multiple loads.
If you have any questions about these devices or multi-channel Z-Wave support in general, feel free to ask below.
