Sensor Test & PowerG Signal Strength
Just moved and having trouble connecting IQ Hub with Tyco wireless sensors. I’ve looked up how to get them to detect and the “Sensor Test” under advanced settings and system tests it won’t let me click along with the PowerG Signal Strength. How can I connect the sensors? They were previously installed but are on/working as I see them light up every time the door opens
I checked your panel and there does not appear to be any sensors programmed. You can find instructions on adding sensors in the link below. Auto learn would be the best option and press and hold the learn button on each sensor until the LED flashes orange. Double check the serial number to confirm you have the correct sensor.
When I go to settings - advanced settings, there is no “installation” button to press
Are you using your master code or the installer code? For those settings, you need to use the installer code.
You will need to use your system’s installer code or dealer code to access that part of the panel’ programming. The default installer code is 1111 and the default dealer code is 2222.
If you need to reset your system’s installer code or dealer code, instructions to do so can be found here:
