The DSC PowerG Wireless Outdoor Contact PG9312 is compatible with all Qolsys brand IQ Panels with a PowerG radio, including the IQ Panel 4 IQP4001. It offers PowerG encrypted technology to protect wireless signal and can be hidden in the door or frame so it won’t affect your decor.
Sensor Specs
Manufacturer | DSC |
Part number | PG9312 |
Dimensions | 4.12 x 2 x 1.37 inches |
Wireless signal range | 2000-2500ft in open air |
Signals | Alarm, alarm restore, tamper, tamper restore, low battery |
Transmitter frequency | USA: 912-919 MHz |
Wireless protocol | PowerG |
Battery life | 5 years (with typical use) |
Operating Temperature | -40°C to 66°C (-40°F to 151°F) |
Battery | Two 1.5 V lithium batteries |
How to Install the PG9312
Physical installation of the PG9312 Outdoor Contact sensor should follow the manufacturer’s instructions found in the product installation manual. Installation steps from the PG9312 manual are below:
A link to the PG9312 full manual can be found here:
Mounting the PG9312
Sensor Installation
- Insert a flat-head screwdriver into the slot provided
and push upward to remove the decorative cover. - Unscrew the lower screw from the device cover.
- Separate the device from the bracket.
- Mark and drill the required number of holes in the
mounting surface. - Screw in the bracket with the four screws provided.
- Reattach the device to the bracket.
- Mount the magnet base with the two supplied screws
to an adjacent surface and attach the magnet to the
magnet bracket
Programming the PG9312 with the Qolsys IQ Panel
Place the IQ Panel into Auto-Learn Mode. To do so, at the panel navigate to:
- Settings
- Advanced Settings
- Enter your Installer or Dealer Code
- Installation
- Devices
- Security Sensor
- Auto Learn Sensor
With the panel in Auto-Learn Mode, open and close the door to trip the sensor.
Program the sensor as needed. Then Click Add to finalize programming.
Programming Instructions for Qolsys PowerG sensors like the PG9312 can be found here:
