Questions about wired POE video
I’m looking at getting a Surety Complete package including 4 wired outdoor cameras. A few questions:
  1. Is the SVR210 compatible with the wired AI cameras (ADC-VC727P)?
  2. Looks like I’d need a POE switch for the 4 cameras. Is that included, or do you have recommended models?
  3. Are SD cards included with the cameras and/or are they necessary when using an SVR?
  4. Is the WiFi Smart Gateway (ADC-SG130) needed/recommended for a setup like this?
Yes, the SVR210 and the ADC-VC727P are compatible with each other
Alarm.com recommends the TP-Link TL-SF1005P (4 PoE ports @ 67W total power)
SD Cards are not included with the camera but they are recommended as a backup incase the SVR210 or the hard drive have any sort of malfunction. The link below has a list of recommended security SD Cards
If you use four ADC-VC727P with the TP-Link TL-SF1005P POE switch, you do not need the Smart Gateway as the cameras will communicate to alarm.com through the ethernet wire which is providing both power and internet.
