Security Camera SD Cards
Using an SD card with a security camera gives you independence from network-based storage. It means that during an event of a network outage, the security camera can keep recording and saving footage on its SD card.
Alarm.com Camera Compatible SD Cards
Not all surveillance/industrial-grade SD cards are compatible with alarm.com on-board recording. The SD cards listed below are likely to give you the best results.
Alarm.com cameras use microSD cards, not full-sized SD cards.
These SD Cards are officially supported by Alarm.com:
- Western Digital Purple microSD cards (64GB - 1TB)
- Micron Industrial Memory cards (32GB - 256GB)
- Samsung Pro Endurance (128GB - 256GB)
- SanDisk High Endurance
- SanDisk Max Endurance (32GB - 256GB)
- Transcend 460T (64GB - 256GB)
These SD Cards are not officially supported by Alarm.com but have been reported as compatible by users:
- TeamGroup High Endurance (64GB - 256GB)
Surety can’t guarantee SD cards in the unofficial list will work without any issues. If you’ve used a surveillance-grade SD card with Alarm.com cameras not listed above and it worked without any issues, let us know and we’ll add it to the unofficial list.
Reliability and Endurance
Surveillance SD Cards are designed for reliable performance in harsh environments, such as extreme temperatures, humidity, and vibrations, which are common in surveillance setups as well as withstand continuous read and write operations, which is crucial for 24/7 video recording. They have higher endurance ratings, measured in terabytes written (TBW), indicating how much data can be written over the card’s lifespan.
They often include superior error correction codes (ECC) and are designed to maintain data integrity over long periods. This is vital for maintaining the reliability of surveillance footage where data loss could be critical.
Cost-effective
SVRs are usually used to record 24/7 but they come at a hefty price. Going for SD cards on the other hand is a cost-effective solution.
Recording without Audio
| Recording Quality | 32GB | 64GB | 128GB | 256GB | 512GB |
| Low: 640x360 10 fps | 7 days | 15 days | 30 days | 60 days | 119 days |
| Medium(default): 1280x720 10 fps | 4 days | 7 dyas | 15 days | 30 days | 60 days |
| High: 1920x1080 15 fps | 2 days | 4 days | 7 days | 15 days | 30 days |
| Max: 1920x1080 30 fps | 1 day | 2 days | 5 days | 10 days | 20 days |
Recording with audio
| Low: 640x360 10 fps | 6 days | 13 days | 25 days | 50 days | 100 days |
| Medium(default): 1280x720 10 fps | 3 days | 7 days | 14 days | 27 days | 54 days |
| High: 1920x1080 15 fps | 2 days | 4 days | 7 days | 14 days | 28 days |
| Max: 1920x1080 30 fps | 1 day | 2 days | 5 days | 10 days | 19 days |
