Qolsys Low Battery
Been having a low battery error on a hardwire translator. Checked the battery with a multimeter and the battery is property voltage, so is the charging circuit and the transformer. There’s a siren and 6 glass break zones. I tried unplugging the battery and transformer for 1 minute, then plugged the battery then the transformer and let it sit for 24 hours, now 2 days later it’s still showing low battery. I don’t want to swap out the board as I don’t think that’s the problem, could it be the glass breaks causing too much draw?
I’m not seeing a Surety account related to this user, so I can’t verify devices.
To best assist we would need the model numbers of all the equipment, the translator, siren, and the glassbreaks. Different devices will have different current draw. What are the AH specs on the battery as well?
