System installed at a second home/remote location. Several months back my IQ2+ panel stopped responding. I was without service for a few months before I could return to the address. A panel reboot seemed to solve the problem.
A few days ago the I received another “not responding” message. Fortunately, I was coming to location this week. Unfortunately, it seems the panel is dead.
Panel was off when I arrived. I attempted to start it by holding the button.
Red light came on briefly. Then turned to a flashing green light. Screen is glowing slightly, but still black. No logos appear. Looking through this forum, I saw some other identical situations and followed the troubleshooting steps listed there.
Power supply and wire is original provided with the unit. 5.5v power supply checks out as good with a multimeter. Battery is NOT bloated and looks fine. Battery and Power disconnected for 1 hour. Does not fix problem.
Based on this, its seems the unit has an irreperable hardware failure and needs to be replaced. Unit is beyond the 2yr warranty. What fun. Doesn’t any company make a product with a shelf life beyond a few years?
Questions:
I have a mix of “power g” and older sensors in the home (legacy from my previous Honeywell panel). I’d rather not have to replace sensors.
Can I replace with something other than Qolsys? (currently very disappointed with the poor quality of their products).
How do I figure out if I have a 319.5 or 345 version? I have these panels installed in a few homes and I have both versions. Not sure which is which. Can’t check the panel since it’s non-functioning.
I’m probably stuck with Qolsys and know I have to get the current V4 panel. If I order today, how quickly can I get it? Tomorrow (Friday)? I’m only here for the weekend. If I can’t get it tomorrow, that means I’m probably without service for another few months until I get back here. The last panel outage cost me a bit of $$$ being unaware of a problem. I’d like to avoid that again.
Edited to add:
Also, with a replacement panel, will I have to re-enroll all my sensors, codes, schedules, and x-wave devices? Or is there a way to transfer the old data over thru Surety? (Can’t do it from a dead panel). If you can do it, how long do you keep the stat from a cancelled account? (If I can’t get a new panel quickly, there’s no point in paying for several months of service on a home that has no panel)
