The Qolsys IQ Remote PowerG IQR-PG is compatible with the IQ Panel 4 with PowerG Radio. A secondary touchscreen that replicates your main IQ Panel in up to 3 additional locations around the house. Communicates via PowerG or Wi-Fi.
Device Specs
| Manufacturer | Qolsys |
| Part number | IQR-PG |
| Mounting | Wall mount or table stand (included) |
| Dimensions | 4.6″H x 7.52″W x .76″D |
| Screen Type | 7″ capacitive glass |
| Screen Resolution | 1024 x 600 |
| Power Supply | Input 100-240VAC 1A/ Output 7V 1000mA |
| Speaker | 1W x1 |
| WIFI | Dual band 2.4 and 5GHz |
| Software Updates | Over the air, WIFI |
A link to the full IQR-PG Installation Manual can be found here:
First step before panel programming
Minimum Software Requirements:
IQ Panel 4 and IQ4 Hub - v4.3.0
IQ Pro – v4.2.1n.
Do this first before pairing to the IQ Panel 4
- Update the primary panel to the minimum software listed above first. Upgrade steps and firmware patch notes can be found here for the IQ Panel 4
- Connect the IQR-PG to Wi-Fi (if available*) or the main panel’s built in access point
- Pair the IQR-PG to the primary panel via Wi-Fi and it will immediately download the required image
- If the IQR-PG is going to be paired via Wi-Fi no further action is required.
Programming the IQR-PG with the IQ Panel 4
PowerG ENROLLMENT Steps:
- On primary panel, Start AutoLearn process as indicated in the primary panel
manual. For manual installation, enter the Device ID 380-XXXX. Device ID can be found on the IQ Remote PG. - On the IQ Remote PowerG enrollment page, select “PowerG pair”.
- The IQ Remote PowerG will be recognized by the primary panel. Configure
options accordingly. - The IQ Remote PowerG will move to the home page.
WI-FI ENROLLMENT:
- Enable Wi-Fi on the IQ Remote PowerG (same Wi-Fi network as the primary
panel). - From primary panel, start process for pairing IQ Remote using Wi-Fi.
- Press “Wi-Fi Pair” on IQ Remote PowerG enrollment page.
- The remote will connect and start looking for software updates (if a new
software exists, it will download and install it then go to home page).
Additional pairing instructions can be found here:
