I just moved into a new house and would like to get rid of the currently installed Vivint system and replace it with a Qolsys IQ Panel 4 from Surety. I have an idea of what I need to do but I could definitely use some help, so any input would be much appreciated!
The house originally had a DSC system installed when it was built (~6 years ago), but I’m having a hard time understanding what the Vivint guy tapped into. The DSC panel is still lit up with A/C adapter plugged in, but wires have been cut.
The Vivint panel appears to be the Skypanel and I’m unable to access advanced options since the default installer codes I find on the internet will not work (I do have a user login which the previous owner left with me). The equipment I’m pretty sure will need to be replaced is:
-Vivint panel
-All Vivint door/window sensors
-Both Vivint thermostats (I happen to have 2 new Ecobee3 lites to replace them with, so hopefully those will integrate OK).
-Both Vivint glass break sensors
-Vivint doorbell/camera
-One Vivint exterior camera
What I’m hoping to save is the following, but please let me know if you envision any issues:
-Three door locks (two are Kwikset and one is Yale)
-DSC motion sensor
-Two Ecobee3 Lite thermostats as noted above
-Some of the DSC panel with battery backup (not sure if this is even needed or recommended)
-Both GoControl garage door controllers
I had plans to buy an inexpensive Z-wave hub or USB stick and pull as many sensors over to that as possible prior to removing the Vivint panel. Is this something I should do, just to be sure the sensors are properly removed from the Vivint system? Do you see any issues utilizing the above equipment I’d like to keep?
Many thanks for the help, and here are a few photos of the exact equipment I have:
