You can manually enter the number then test the sensor.
The ID you are looking for is 7 digits. This will be labeled as the ID on a sticker on the sensor itself.
To manually learn it in you will need to change the signal input type from the default 319.5 to PowerG in the bottom right of the sensor settings page where you would type in the number.
