I am trying to include a DSC PG 9945 sensor into my Qolsys Plus panel and have been unsuccessful in getting it to do so via auto learn. I do not see a 6 digit / alpha id that will allow me to include in manually. I have had other power g devices in operation for sometime without any issue. Any help will be greatly appreciated. Thanks
You can manually enter the number then test the sensor.
The ID you are looking for is 7 digits. This will be labeled as the ID on a sticker on the sensor itself.
To manually learn it in you will need to change the signal input type from the default 319.5 to PowerG in the bottom right of the sensor settings page where you would type in the number.
