Panel blank and flashing green light
Possibly this?
this is IQ panel 2 I have been using for a while. All is a sudden just want bank and flashing green light. I have try reboot but went back to blank screen and blue light. DO I need to change the battery?
It could be the battery, power supply, or general hardware failure. Run through the steps in the below guide and let us know what you find.
no power lost. just the panel . just BLINKING GREEN LIGHT. and BLANK SCREEN
Did you try all the steps in that prior post? If you haven’t yet, try those last couple steps.
To identify if the battery is causing a problem specifically, power down the panel (Settings > Advanced Settings > Power Down). Open it up and unplug the battery. Try powering it without that batter connected temporarily. Is there any change in behavior?
If not, you are likely looking at hardware failure and it would need to be replaced unfortunately.
Qolsys previously informed us that there are cases where the battery removal does help. It is a power application issue it appears, and could be related to either the panel’s board having a failure, the battery, power supply, etc., which is what those last couple steps in the guide are trying to isolate.
It looks like you have all 319.5Mhz sensors, is that correct? For all 319.5 sensors the lowest cost new replacement would be an IQ Hub, which can be found here.
