Need assistance on alerts
Need assistance on recent alerts on our system
It looks like there are a few, but most importantly I am seeing a cellular communication failure and a panel tamper. Are these the alerts you are referring to?
The first step to address the cell issue should be updating firmware. The IQ Panel 4 requires incremental updates, and you are currently at 4.2.1. Follow the steps in the link below to update to 4.3.0, then you can update to 4.4.2, then to 4.5.2. The patch tags are required.
After the updates does the cell communication error resolve?
Panel tamper indicates that the backplate is not securely fashioned and the tamper switch is not depressed inside. Steps to troubleshoot are linked below:
I also see a low battery for one of the thermostats which should be replaced.
