Hello.
I’m setting up the new nami system here in my home as an evaluation. I ran into two small issues and have a couple of questions.
Issues:
During the joining of the devices the alarm.com app actually locked up when adding the motion sensor. So, when I went back into the app, I had to do the ‘add additional sensor’ option to add the rest of the components. That went ok, but I then didn’t have the ability to enter the system test mode as the instructions indicated.
Is there a way to manually run the system test to verify everything?
(Edit: Please disregard - I found the setting in the app to launch the test mode. Security System > Gear Icon > System Test) -
Also, the motion sensor has a broken tab on the battery compartment. (one of the two tabs on the ‘twist lid’ that covers the battery fell out when I opened it.)
I was able to get the battery to seat with just one tab, but just wanted you to know. I’m thinking it was broken from the factory, as when I first opened it I noticed the battery door was seated a little crooked. The sensor is working, however.
Questions:
An odd question: The directions say there should be a blue LED on the motion sensor but honestly I can’t find any light at all. Same for the door sensor - directions say there should be a white LED but I can’t find that either. In any case, both are joined and working. But if you have a pic of where that led should be maybe that would be helpful. Or maybe I just need thicker glasses.
I just want to be sure I understand the alarm.com plans required for nami. From reading the plan page, am I correct in this understanding:
- To control the wifi sensing plugs, I would need Complete or Home plans.
- However if I purchased the Alarm only plan, the sensing plugs would still do their sensing thing, but they would not be controllable from the alarm.com app. Is that correct?
When adding the extra sensing plugs and door sensor (part of the AWARE 10 kit) to this existing ALARM 15 kit I just installed, should I add those items as individual sensors in alarm.com, or choose the option to install the AWARE 10 kit itself?
(For future knowledge) Can the AWARE 10 kit can be a standalone purchase if you only want activity awareness and not alarm features, or must all purchases/installs start with the ALARM 15 kit as a base?
Thank you for your help!
