csdevane
(Christopher)
June 26, 2022, 4:06pm
1
I am attempting to add two garage doors through a MyQ controller, but the only options that show under add device/garage doors are overhead door and genie. I have attempted through the app and web.
Am I missing a step?
Audel_G
(Audel G)
June 26, 2022, 5:19pm
2
This thread might help:
Before setting up MyQ garage doors on Alarm.com, consider using the Ecolink Z-Wave garage door controller instead as an alternative approach that may give you a better garage door experience.
[821lm]
821LM, 821LMB, 821LMC-S, MyQ-G0301, MyQ-G0401-ES
The LiftMaster MyQ Smart Garage Hub is a kit that allows you to integrate a wide range of Garage Door Openers with your Alarm.com account.
It supports two non-MyQ garage doors when coupled with a tilt sensor and up to 16 MyQ devices, such as an …
To put it in general, basic terms you must first connect the garage controller to wifi then you must add that controller to your alarm.com account (usually via serial number)
Audel_G
(Audel G)
June 26, 2022, 5:20pm
3
Another reference that might help:
I have a WiFi-enabled garage door opener from LiftMaster. From reading through the various support posts on LiftMaster and Chamberlain, the secret sauce seems to be not registering the device with MyQ.
However, I can’t seem to find a way to program the device for WiFi without using the MyQ app.
After connecting the LiftMaster opener to WiFi, I then attempt to register the serial number through ADC. At that point, I get an error (“Registration was unsuccessful for this device. Please factory re…
MyQ is an optional add-on which can be enabled in the system manager. Make sure you have it enabled first by visiting the system manager here .
