My Q missing from IQ Panel
I just realized since replacing my panel from IQ Panel 2 to IQ Panel 5 that MyQ Garage door is missing and not showing on the panel. It still shows in the Alarm.com app though. Please let me know what needs to be done to have it show on the panel. Thanks!
Hey Ryan, thanks for posting!
myQ integration on the IQ Panel is automatic and gets sent over from Alarm.com, so after a panel swap it sometimes doesn’t carry over to the new panel on its own.
It looks like your IQ Panel 5 is already on the latest firmware, so that part is covered. A couple of things to try:
  1. Make sure the garage door works both from the wall button and from the Alarm.com app.
  2. Reboot the panel.
If the garage door still isn’t showing on the panel after that, just let us know here and we can send some commands from our end that should get it showing.
Here’s our guide on this for reference: How to troubleshoot myQ garage control not showing on Qolsys panel
Good afternoon - The garage door works from garage keypad, outdoor keypad, and from the Alarm.com app. I also rebooted the main panel and the garage door still seems to be missing. If you can please try from your side for commands to panel, otherwise I did read somewhere i believe in this forum when you replace the panel it sometimes requires the provider to remove MyQ and then I would have to re-add it afterwards.
Hey Ryan, thanks for trying all of that!
We’ve sent some commands from our end to update the statuses on your account. Can you check the panel and let us know if the garage door is showing now?
It’s still not showing, I also rebooted the panel again as well.
Thanks for checking, Ryan. We’re still looking into this and will follow up here once we have an update.
Hey Ryan, thanks for your patience.
The next step is to remove the garage door opener from your account and add it back to your existing myQ gateway. We’ll handle the removal on our end. To add it back, you’ll need to be at the garage door opener, since it has to be put into learn mode at the opener itself.
When would be a good time for you to be at the garage so we can do this together?
@Alfred Ill be home around 4:30 PM EST would it be possible for you to delete and when I get home I can add it back?
Hey Ryan, yes, we can do that! We’ll remove the garage door opener so you can add it back when you get home.
@Alfred The garage door is still showing in the app and online, can you please let me know when it’s deleted?
Hey Ryan, the garage door opener has been removed from your account. Your myQ gateway is still connected, so you can add the opener back from the Alarm.com website. This has to be done on the website, not the app.
Our guide walks through it here, in the Register Internet Gateway section: How to set up a LiftMaster MyQ Retrofit with Internet Gateway and Control Panel through Alarm.com
Since your gateway was already connected to Alarm.com, press your garage door wall button a couple of times before adding the opener back.
Let us know once it’s added and whether it shows up on the panel!
@Alfred I got the garage door re-added and now it is showing up on the panel. Thank you so much for your help and assistance!
Awesome, glad to hear it’s showing up on the panel now, Ryan!
Please let us know if there is anything else we can do to help.
If not, would you be willing to review Surety on Trustpilot and Google? I would really appreciate it! Just click here:
Review Surety on Trustpilot
Review Surety on Google
Thanks so much!
