My Alarm Duplicate Armed without Me Arming it - Help
It did it again this morning. 2 nights in a row at the exact same time around 2:45 to 2:50 AM
It should be noted that I reprogrammed every z wave rule and schedule from scratch when I upgraded to the new panel.
Since this is in out master bedroom it is very startling. Please help!
Looking into the available logs with Alarm.com, it still appears to correlate with Z-wave. The only correlation and possible instigation we are seeing is that this seems to occur following a modem ping, which in turn follows a previously sent list of Z-wave commands (often schedule edits)
In both cases you just mentioned we are seeing a few Z-wave commands start to hang earlier prior to the reboot.
If this is indeed a type of buffer issue related to Z-wave, there may already be a fix for it. 2GIG firmware 1.17 includes support for Z-wave command queuing, which will help the module process the commands in sequence.
1.17 is available for OTA and this account has a Go!Bridge, so we could apply it if you would like. Please confirm if you would like us to go ahead and send that.
please send the update of 1.17
Started now, make sure not to power down the GoBridge or Panel during this time. Go!Bridge updates don’t usually take too long.
