I realize one issue is with 2GIG and the other is with ADC, but I am not following the logic of how this is not an ADC issue due to the issue occurring at the same time, history of their responses that eventually point to ADC as the issue, and the infrequency of occurrence.
There is no link between the two issues so I would urge separation.
If there was a hardware issue, I doubt it would be happening at the same time.
We can’t say there is a definitive hardware issue, but we cannot rule that out based on the information available so far. The only thing we can completely rule out in fact is an acute remote cause.
If I had to guess, I would agree with the above statement that the firmware version played a role in the cause. Since it is not a common issue and has not been replicated, there is something specific to the system which lends to the issue.
Also due to their late rollout of firware fixes and secondary panels for the GC3, this makes this change a highly undesirable option
While we are also very eager for the firmware effects, the timeline is fairly standard for the manufacturer, and secondary panels have been released roughly a year or more after the primary panel for almost every system. If January is accurate, that’s actually a little quicker than precedent.
Unfortunately I realize that makes the GC3 a difficult replacement now if you have components which require an update. I do wish they had verified complete Z-wave compatibility, but similarly, there is no precedent for that with any other system.
The issue occurring at a similar time intermittently actually very strongly suggests a panel process is at fault.
I presume you mean the DST issue regarding the history. While I do not have specific details regarding what developers needed to change, the issue was not universal. It was an issue that appeared to largely affect older systems. (Simon panels predominantly, and some older model Go!Control panels). I’m not sure the resolution was the same between the different panels (it very likely was not), but most likely the rules created needed to be finely adjusted to account for hardware differences.
Unfortunately the infrequency of this makes it harder to track, as there may be things you could test or observe that may help if you had a realistic expectation of when it would next happen. Going off of the time of occurrence and knowing it is resulting in a reboot, it’s likely a panel software process error.
2GIG suggested replacing the communication module as a test at first, but I would not suggest that myself yet. We are still discussing the issue with the manufacturer. I think the post above was just meant as an update.
