I have begun to experience many problems with Z-wave functionality (and a, supposedly, a panel power issue) after updating my IQPanel 2+ from 2.6.3 to 2.7.0 this past Saturday. Issues include the following:
My two Schlage BE469ZP deadbolts do not respond to remote commands. However, they both report status correctly. The issue is very reminiscent of this previous issue, which Jason helped with and ultimately required some combination of an upgrade panel firmware and Z-wave SDK to 6.81 to correct (if memory serves). Note that I am now using more modern Schlage BE469ZPs than I was at that time - they are both manufactured more recently and fall within the documented date range for full ADC compatibility (newer than January 2021, if memory serves).
Couple of instances of ADC-supported light switches/Z-wave nodes hanging completely, seen across two different devices. Light switches in this condition not only will not respond to Z-wave commands, but also cannot be turned on or off via the physical switch (have to open the breaker to reset them, after which they work normally again).
Aeotech home energy monitor has stopped reporting data. This was a key variable in the original problem. I reset it, but no better behavior. I also unplugged in for a short period of time last night to reset the panel and retry my lock functionality, but this didn’t seem to make a difference.
After rebooting the panel last night (and ever since), the panel has been reporting an AC power failure (both locally on the screen, as well as via ADC). However, it has AC power. The panel itself even reports that it is charging the battery. I rebooted the panel a second time, but no difference in behavior.
I’ve also performed a network rediscovery, but with no difference in behavior at all.
I ran ALL tests for the panel, and they ALL passed. Run selective Z-wave tests to both locks, HEM and no problems there, either. I turned off WiFi, unplugged the HEM and rebooted the panel - no changes to any of the above, so I reconnected everything.
Please help…? I’m really regretting having performed that update!!
