Hi folks, on Qolsys IQP2+, I do not see an option to remove the ENTRY delay for Arm Stay in Settings > Advanced Settings > Installation > Security and Arming.
The Arm Stay - No Delay option in that settings menu there only seems to remove the EXIT delay (which is confirmed by the description of the setting that says Arm stay immediately without a countdown timer).
Where/how can I remove the entry delay for armed stay by default?
Thanks,
-Leo
You cannot. This is not a global setting, you can choose to arm without entry delay each time you arm the system either stay or away, both at the panel and remotely through Alarm.com.
If your plan supports automation features you can also create an Alarm.com scene which arms the system and select No Entry Delay, so that whenever you run that scene either from the app or as a home screen widget on your phone, no entry delay is applied.
I see, ok, thanks for clarifying that Jason
