Iq4 Panel Migration from ADT to Surety
Hi, I’m on the eve of being free from ADT and they have assured me they will be canceling my alarm.com account with them and releasing my IMEI (we’ll see how that goes)
When I sign up for a Surety account, is there anything I need to do with my panel or will it function as it’s currently set up? Do I need to change any settings on the panel like disarm codes or re-enroll sensors and assign zones?
Hey there, congrats on almost being done with ADT!
You won’t need to change anything on the panel to make the switch. Your sensors (with their zone settings) and Z-Wave devices are programmed in the panel itself, so when ADT terminates their Alarm.com account, none of that gets wiped. Once you connect to your new Surety account, there’s nothing to re-enroll.
What doesn’t carry over is anything that lived in ADT’s Alarm.com account. After activating, you’ll set up your notifications, rules, user access, and emergency contacts in the new account, and add back any cameras or other Wi-Fi devices. Any third party integrations need to be removed from ADT’s account before they can be added to the new one.
A few things to have ready:
  1. Once ADT says it’s done, run your IMEI through our Module Check Tool to confirm it’s actually released: Can I activate my equipment? - Surety Home
  2. You’ll need your Master User Code or Installer Code to run the cell test that connects the panel to service.
  3. If ADT left their own installer or dealer codes on the panel, those can be reset remotely once you’re connected, through System Manager in your Surety account: My Account - Surety Home
Full rundown of switching an existing system: Monitoring an Alarm.com System You Already Have: How To Switch to Surety - Surety Home
Step by step on the forum: How to Switch to Surety Alarm.com Monitoring Services
Plans: Smart Home Automation & Security Plans | Surety
Let us know how the switch goes!
So the master user code, the one that we use to disarm the panel, lives on the panel not the alarm.com account? We have our master code, installer and dealer codes.
That is correct.the Master Code, Installer Code, and Dealer Code are a part of panel programming.
You will need one of those codes to run a cellular communications test to connect the panel to service during the account setup process.
While those numbers can be changed through Alarm.com remotely, the panel must be connected to service first before that can be done. You may need one of those codes to run the cell test before being able to connect to service.
So service ended however the alarm.com account is still registered. I called ADT and they’re telling me that there’s a 30 day hold on the alarm.com account from the day of service termination. After that 30 day period, the IMEI will be released.
I had asked if that’s a specific ADT policy or an alarm.com one and they’re telling me it’s the latter. Does this sound like a line they are feeding me? From reading here it seems like the cancelation of the account is instant, unless ADC operates on a monthly basis and ADT has already paid for the current month.
On the Alarm.com dealer side, cancelling an account only takes a few minutes, and once it’s cancelled, the IMEI is released right away. Alarm.com doesn’t have a 30-day hold, so this would be an internal policy on ADT’s end.
We’d recommend contacting ADT again and asking them to terminate the Alarm.com account immediately so the cellular module is released. If it helps them find the account, you can give them your panel’s 15-digit IMEI.
Once the module is released, you can check its status here: Can I activate my equipment? - Surety Home
Let us know if you have any questions.
Yeah I’ll get back on the phone with them again. I no longer have monitoring from ADT when I log into my account but I still have access to the Control app (rebranded ADC app) and I can arm disarm remotely through it so the account is definitely still active.
If you still have remote control over the panel through Alarm.com, then the panel is registered.
You can confirm registration by entering your module’s 15-digit IMEI number into the tool below. Once it is unregistered, the system can be connected through Surety.
Sent a strongly worded email and they terminated the account. I’m all up and running with Surety!
