cmurlin
(Christopher)
September 25, 2025, 4:38pm
1
My IQ Panel 2 rebooted and will not come back up. The red light stays on and nothing is showing on the screen. I have disconnected the battery and power and rebooted. Still does the same thing.
nicholas
(Nicholas)
September 25, 2025, 5:25pm
2
Is anything else happening when you try to power it on, or is it going straight to a red LED?
Steps to resolve an unresponsive IQ Panel 2 can be found in this guide:
If you find that your panel unresponsive there are a few things you should check.
Has the panel lost power?
Did the whole residence lose power, or just the panel?
Can I interact with the panel, or is the screen blank?
Are the LEDs on and if so, what color are they?
Is the screen black, or does the backlight still turn on?
The panel is plugged into power via an AC transformer into a power outlet:
Is the outlet off/not working? Check to make sure the outlet isn’t switched off
Try a…
