If you find that your panel unresponsive there are a few things you should check.
Has the panel lost power?
- Did the whole residence lose power, or just the panel?
Can I interact with the panel, or is the screen blank?
- Are the LEDs on and if so, what color are they?
- Is the screen black, or does the backlight still turn on?
The panel is plugged into power via an AC transformer into a power outlet:
- Is the outlet off/not working? Check to make sure the outlet isn’t switched off
- Try a different outlet as a test
How is the panel powered? It should always use the included power supply and either:
- The included cable, or
- An existing cable run that meets the specs outlined in the manual on page 11.
Power cycle the panel. Leave the panel off for at least 20 minutes. Steps on how to do so safely can be found here.
- Check to make sure the power cable is firmly attached and wiring is not loose or corroded.
- Check the internal battery to ensure it is not bloated or disconnected. A bloated battery is bad and should be disposed of.
If powering down via the steps in Step 5 do not resolve, try it again but do the following:
- Power Up the panel with just the AC power connected, do not plug in the battery;
- Power up the panel with just the Battery connected, no AC Power.
Note: If able, check power supply with a voltmeter to ensure the power supply is producing the correct printed voltage.
