IQ Hardwire PowerG
The IQ Hardwire PowerG Wired to Wireless Converter converts existing hardwired zones to PowerG wireless zones. It provides eight hardwired zones, four programmable outputs, supervised output for siren/strobes, up to 18 conventional 2-wire or 4-wire smokes, single and double end of line resistor, and front and back tamper protection.
Device Specifications
| Type | Description |
| Power Input | 18VDC, 2.22A |
| Part Number | PG9WLSHW8 |
| Dimensions | 304mm x 396mm x 92mm (11.9" x 15.6" x 3.6") |
| Wireless Frequency | PowerG |
| Battery | 12V7Ah Sealed, Rechargeable Lead Acid |
| Battery Charging Voltage | 13.7VDC, 360mA |
| Maximum Auxiliary Current | 11.3 VDC to 12.5 VDC, maximum current 700 mA shared between the AUX1 and AUX2, CORBUS RED and BLK terminals and PGM outputs |
| PGM 1, 3, and 4 voltage and current | 11.3 VDC to 12.5 VDC, 50 mA |
| PGM 2 voltage and current | 11.3 VDC to 12.5 VDC, 300 mA |
| Bell Output | 11.3 VDC to 12.5 VDC, maximum current 700 mA continuous |
| Usage | Indoor Only |
| Operating temperature | -10°C to 55°C (14°F to 131°F) |
| Humidity | 5% to 93% RH non-condensing. |
