IQ 2 Stuck on Reboot
My panel was blinking on and off so I decided to reboot it using the panel’s reboot.
It appeared to be rebooting but then got stuck at the Qolsys logo and the light flashing green.
I waited but nothing.
I tried to hard restart using the power button and watched it reboot.
Loaded 100% of the Qolsys system and then back to the logo and stuck again.
Any ideas on possible next steps?
Here is the screen prior to getting stuck on the logo.
Perform a power cycle, leaving the whole system off. Steps on how to do so safely can be found here:
  • Leave the panel off for about 20 minutes.
  • Check wiring from power supply to panel to ensure no damage or that anything has come loose.
  • Check the battery to ensure it is not bloated/pillowed
When troubleshooting, you may want to place your 24/7 professional monitoring account on Test Mode during troubleshooting to avoid any false dispatches.
You can do this by calling monitoring operators directly at 855-348-0367 or from the Test My System tab in the System Manager section of your Surety account.
I disconnected it completely for ~60 minutes. Reconnected and still got stuck.
It is/was weird, the panel was having issues, it was flashing occasionally and I initiated a restart from the panel itself through the menus, didn’t think much of it, came back a few hours later stuck on the logo.
Then I tried a hard reset. Then the total power off and restart.
Tossing in the towel and already ordered a new IQ Panel 4 from you all.
Sounds like hardware failure. Typically the Hard Reboot (holdling down power button for 30 seconds) is a bit of a last resort and may resolve issues unrelated to power or hardware failure.
