My tx-6010-1 smoke alarm kept giving false alarm so i removed it. Apparently can no longer buy this.
How do i know if these other smart smoke detectors will work with concord 4 and i can replace ?
Thanks
Thanks
The Concord 4 works with 319.5 Mhz wireless sensors. Options that should work include the Qolsys IQ QS5110 smoke detector and the Alula RE114 smoke detector.
So.my panel is complaining about the missing sensor. If i get one of these compatible all ineed to do is screw it in and it will work?
Sounds too easy to be true!
No, not quite. You would need to program the sensor into your panel. (and remove the current sensor programming) Instructions to program new sensors and remove sensors from the panel are found in the guide below.
Oh well i dont know my installer or master code so thats a whole another problem.
The concord panel complains like 8am 9am 8pm 9pm every day about the missing smoke alarm. In the meantime we could still arm the system as normal for doors windows motion right?
The smoke sensor tamper is separate and shouldn’t trigger the main alarm?
Thanks
The master code is your user code associated with your primary user in Alarm.com. You can edit your master code at any time there under the Users page.
Your installer code has been reset to its default value 4321 so that you can access programming.
You should be able to arm regardless of the malfunctions, but for reference, a tamper on a burglary zone that occurs while armed would cause an alarm.
I would recommend deleting the zone if the sensor is not in use to avoid the notifications and error messages.
