Program sensors on an Interlogix Concord
Security sensors must be enrolled locally on an Interlogix Concord, but some settings (i.e., sensor groups) can be remotely configured after sensors are enrolled.
An alpha-numeric keypad is recommended for programming.
Key Function # Select item (Enter) * Go back one tier (Escape or exit) A Scroll up within the menu B Scroll down within the menu C Insert pause when entering phone numbers D Delete (where applicable) 1 Off (where applicable) 2 On (where applicable)
Programming mode
To enter programming mode on the keypad:
- Press [8] .
- Enter the installer code (default is 4321).
- Press [00] for the command. The screen displays System Programming .
- Press [#] to enter programming mode.
To exit programming mode on the keypad:
- Press [*] until the keypad displays System Programming .
- Press [A] and the screen displays Exit Programming . The Ready light blinks.
- Press [#] and the display returns to the time and date.
To enroll sensors locally using the keypad:
- Press [8].
- Enter the installer code.
- Press [00] for the command. The screen displays System Programming.
- Scroll to Sensors, then press [#] to select.
- Scroll to Learn Sensors, then press [#] to select.
- Enter the sensor partition number, then press [#]. This is typically 1 for partition one.
- Enter the sensor group number, then press [#]. For information about sensor groups, see Interlogix Concord Sensor Groups.
- Manually trip the sensor to be recognized by the panel.
- To save time, all sensors can be tripped at once, and then the sensor groups can be updated later.
- Once new devices are added, open, close and tamper the device to ensure it is working locally.
Note: With the exception of tripping the sensors, the process for enrolling new sensors is the same for wireless and hardwired devices.
To remove sensors using the keypad:
- Press [8] .
- Scroll to Sensors , then press [#] to select.
- Scroll to Delete Sensors , then press [#] to select.
- Scroll to the sensor to remove, then press [#] to remove the selected sensor. The screen displays Done when a sensor is successfully removed.
- Continue to remove any other sensors, or exit programming.
