Panel firmware patch notes and updates can be found here:
For Video Cameras, you can check for updates cia tha Alarm.com website, Video > Settings > Video Device Info.
Thanks, the Panel Update worked fine, except, I have run a Z-Wave check network 2 times, and it crashes the panel. Finally, on a 3rd try, it worked. Should I be concerned?
This is not an issue we have encountered previously. When you say crash, did it occur during or after the Z-Wave Network check? How long after the panel update did you run this check?
Currently, all Z-Wave devices (save for the one outlined below) are reporting a good link quality and that they successfully partook in a Z-wave network rediscovery on 9/19/2022
One device is in malfunction: Node 11 - Den You may need to delete the device locally, then re-add.
I ran the check right after the firmware update. During the running of the check, the panel crashed and rebooted. As I said it finally worked so it may be a SMH kind of thing
