How update system for insurance discount?
The panel is powered by a plug in transformer. If it is wall mounted the power cable will typically be routed in the wall and down to a basement or utility room. Sometimes installers will just pop it out into an outlet under the panel.
You can typically reuse existing wiring, but you must connect the new IQ Panel’s power supply to it, you cannot use the old panel power supply.
