To enroll a Linear Z-Wave Garage Controller into a Z-Wave Network:
- Put the Z-Wave controller into Add Mode.
- Press and release the link button on the GD00Z.
- Verify that the GD00Z was recognized by the Z-Wave controller.
To delete a Linear Z-Wave Garage Controller from a Z-Wave Network:
- Put the Z-Wave controller into Delete Mode.
- Press and release the link button on the GD00Z-4.
- Verify that the GD00Z was excluded by the Z-Wave controller.
To factory reset a Linear Z-Wave Garage Controller (GD00Z):
The reset process should be performed after the device has been deleted from the Z-Wave network. The reset process causes the GD00Z to forget its network information, but it does not remove it from the Z-Wave controller (i.e., panel/module).
- On the GD00Z, quickly press the link button five times in a row.
- The GD00Z will sound a short beep, flash several double red lights, and then sound a long beep when successfully reset.
