How To Program Sensors into a Simon XT
To program a sensor or keyfob using the panel:
  1. Scroll to System Programming , then press [O K] .
  2. Enter the dealer or installer code, then press [O K] .
  3. Scroll to Sensors , then press [O K] .
  4. The display shows Learn Sensor. Press [O K] .
  5. The display shows Trip Sensor ##, with the number signs flashing.
  • When programming (learning) sensors, the panel uses an ascending sequence starting with 1. To program the sensor into a specific sensor number slot, enter a two-digit sensor number immediately. Otherwise, the sensor is programmed into the next available sensor number slot.
  1. Trigger the sensor.
  • The panel recognizes a sensor when you press a sensor program button, press and release a tamper switch, press a sensor test button, or put a sensor into alarm.
  1. The display shows SN ## Grp10 , with Grp 10 flashing.
  2. Enter a specific group number, or scroll to the group number the sensor should use. Press [O K] to accept the group number displayed.
  3. The sensor text flashes. Scroll through the text list, and then press [O K] to accept the first text segment.
  4. More text may be entered, or press [O K] again to finish adding the sensor.
  5. The display shows Trip Sensor ##, with the next available sensor number. Another sensor can now be added, or press [ Status] repeatedly to exit.
Sensor Groups
  • Group 01 = Remote Panic, Keyfob or Touchpad with Audible Police Panic
  • Group 03 = Remote Panic, Keyfob or Touchpad with Silent Police Panic
  • Group 06 = Remote Panic, Keyfob or Touchpad with Auxiliary Medical Panic
  • Group 10 = Entry and Exit Door
  • Group 13 = Window Sensor
  • Group 14 = Interior Door Sensor
  • Group 17 = Indoor Motion Detector
  • Group 26 = Smoke or Heat Detector
  • Group 29 = Freeze Sensor
  • Group 34 = Carbon Monoxide Detector
  • Group 38 = Water Flood Sensor
Delete a Sensor
  1. Scroll to System Programming , then press [OK] .
  2. Enter the dealer or installer code, then press [OK]
  3. Scroll to Sensors , then press [OK]
  4. Press the up or down arrows to scroll to Delete Sensor , then press [OK]
  5. Press the up or down arrows to scroll to a specific sensor, then press [OK] to delete that sensor.
  6. Press Status a few times to exit out of programming
