You can set up a password that must be entered to interact with the Commercial Stream Video Recorder (CSVR) local user interface.
To set a password for the ADC-CSVR126 local interface:
Note: The primary login for the account will be sent an email notification whenever the password is changed.
- Log into the customer website.
- Click Video.
- Click Settings.
- Using the Video Device dropdown menu, select the CSVR.
- Click Local Display.
- In Local Device Password, enter the desired password
- In Password Protection, click to select Enabled.
- Click Save.
Log in using the local interface
Use a connected mouse:
A connected mouse or the ADC-CSVR126’s navigation buttons can be used to log into the local interface.
- Right-click anywhere on the screen.
- Click the Password field.
- Use the virtual keyboard to enter the password.
- Click Log in.
- To exit the login screen without entering a password, right-click.
Use the ADC-CSVR126’s navigation buttons:
- Press [Menu].
- Press and release the down button until the Password field is highlighted.
- Press the center button.
- Press [Esc].
- Press the down button.
- With Continue highlighted, press the center button.
- To exit the login screen without entering a password, press [Esc] until the live video reappears.
Local interface too many login attempts
When the user submits an incorrect password more than five times in a row, the local interface is locked for 60 seconds. Once the 60-second timer expires, the interface is unlocked and the user can attempt to enter the password another five times.
To disable the password for the ADC-CSVR126 local interface:
- Log into the Alarm.com website.
- Click Video.
- Click Settings.
- In Local Device Password, enter the desired password.
Important: The password is required for first-time setup and any time the ADC-CSVR126 loses its connection to the Internet or power.
- In Password Protection, click to select Disabled.
