The Nest learning thermostat can be integrated into your existing Alarm.com account. Google Nest Thermostats are Wi-Fi thermostats that connect with Alarm.com; they are not Z-Wave thermostats.
All thermostat schedules must be configured using the Nest platform. It is a basic integration that only allows control of the target temperature, thermostat mode, and fan mode. It does not support any Alarm.com rule-based automation, Customer Website-programmed thermostat or fan schedules, battery level reporting, or advanced configuration setting.
The following features with Nest are available through Alarm.com:
- Current target temperature control
- Current mode control (Heat, Cool)
- Scene thermostat control including:
- Temperature control
- Mode control
Nest compatibility is included in the following service plans:
- Surety Home
- Surety Complete
To add a Google Nest Thermostat using the Alarm.com Website:
The primary Google login credentials must be used to integrate a Google account with Alarm.com.
- Log into the Alarm.com Website.
- Click Settings .
- Click Manage Devices .
- Click Add Device .
- Click Thermostat .
- Click Google Nest Thermostat .
- Click Begin Installation .
- Enter the primary Google account login information.
