Using an Ethernet cable, connect the device to the network.
If you wish to use a display with your CSVR, please connect it to one of the HD Out ports using an HDMI cable.
Connect the device to a non-switched, grounded power outlet.
For the CSVR2008P/CSVR2016P: Use the switch on the back of the device to turn on your CSVR.
Wait for the device to boot up. A solid green status LED indicates that the device is ready to be added to the account. P
Alarm.com Website
Using a web browser, enter the following URL: www.alarm.com/addcamera. You will need your username and password to log in to the Alarm.com Website.
Select the CSVR from the video device list or enter its MAC address to begin adding the device. The device’s MAC address is located on the bottom of the device or on the packaging.
Follow the on-screen instructions to finish adding the CSVR.
The CSVR20xxP can be mounted to a standard server rack using the included rack mount kit. The rack mounts are designed to fit into a 1U (rack unit) area. The kit includes the screws needed to attach the rack mount ears to the device, but does not include the screws needed to mount the device into a rack.
Gently pry off the rubber footpads from the bottom of the device.
