Lock user codes can be managed using the Alarm.com Website or mobile app.
It is recommended to only manage user codes remotely. It is not recommended to add new user codes locally at the lock. User codes added locally at the lock will not display User information in the Event History of your ADC account when that code is used. This may create conflicts with remotely created user codes.
To add a user code to a lock using the Alarm.com Website:
- Log into the Alarm.com Website.
- Click Users .
- Click Add New User .
- Enter the user’s first and last name, then click Create .
- In Access Code , enter the desired user code.
- A new access code can also be generated by clicking Generate Code .
- Click to select which devices and features the user will have access to.
- Click Save . Allow a few minutes for the system to update before testing the new user code.
- Click the Time to set which times the user code can access the system.
- At all times - Allows the user to access the system at all times.
- Restricted schedule - Create a weekly access schedule for certain times the user can access the system.
- Temporary access - Create a one-time access window for the user to access the system.
- On the Use Profile page, update any additional user information:
- In Contact information , click + Add Contact to add the user’s contact information.
- Tap Language Preference to select the user’s language preference, and then tap Save .
Note: User codes cannot be created while the security system is armed. Verify the security system is disarmed before attempting to create a new user code from the website.
To add a user code to a lock using the Alarm.com app:
- Log into the app.
- Tap Menu Icon
- Tap Users .
- If the user currently has a code for the security panel, tap to select the user to add lock access.
- If the user does not currently have a code for the security panel, tap Add Icon + .
- Tap the access code field. (Key/Lock Symbol)
- In Access Code , enter the user’s desired code.
- Tap to toggle the user access to the specified device.
- Tap Save . Allow a few minutes for the changes to send to the lock, and then test the user code.
- If the user should only have access to the devices during specific times, then tap Time to select the user’s access period to the device. Once the desired access period is selected, tap Save .
- Update any additional user information as desired (e.g., contact information, language preference, etc.).
