So ADC didn’t have all the functionality I’m looking for, but I still want to use it. I’m setting up HomeSeer and I can’t for the life of me find a way to link them together. I read somewhere that the Qolsys has to be the primary controller else you lose all ADC control over Z-Wave (still true?) but anyways as soon as I put the Qolsys in Include mode, HS times out and can’t do the secure link, and then I can’t exclude HS from the Qolsys so I have to factory reset the HS stick, which kills the Z-Wave network, and then I need to re-include all my Z-Wave devices in the Qolsys…
As you can see by my rambling it just doesn’t work. Did anyone integrate these two together, and if so, how?
No, I think the thread you saw was regarding the original IQ Panel, FYI, not the IQ Panel 2. Also, firmware 1.6.1 I think fixed this on the original IQ Panel.
Are you using a Qolsys IQ Panel gen 1, or the IQ Panel 2/2+?
This seems to all work perfectly. I can’t control my door lock though as the Qolsys says it was paired in non secure mode, I’m not sure how to fix that.
In some cases the controller may not share secure keys properly. This may be a limitation of the Primary. I’m not seeing a related Surety account. Your dealer can try to request the secure keys through dealer tools, but I don’t have a very good success record using that. Worth a shot though.
Update for everyone, found on another thread the idea of redoing the Add Controller process a second time, and it worked flawlessly. The last thing I need to fix is that the lock, while able to be controlled by the Qolsys panel and ADC, will not report status to Qolsys since it only reports to the primary controller. Anyone knows how to set a polling interval on Qolsys?
Walkthrough to setup HomeSeer HS4 with a Qolsys IQ2+ Panel
Setup all your devices in Homeseer (remove them from the IQ2 first!)
In Homeseer Z-Wave Controller Management, execute the Send Network Information to another Controller command with the HS Z-Wave stick close to the IQ panel
On the IQ panel with Advanced Z-Wave settings enabled, touch “Add/Remove Controller” under Dealer - Install - Z-Wave devices
Wait for the operation to complete
Check status of locks and lights
If you have issues, repeat steps 2 to 5 - if it still doesn’t work, get the HS Z-Wave interface as close as possible (within 3 feet) of the IQ panel and try again
You should have full control of all Z-Wave devices both from HS4 and the IQ2+ panel/ADC
To ensure status gets populated for the IQ panel and on ADC, click on your device in HS4, then Z-Wave, then Manage
Under Associations, click Update, then drop down to Association Group 2, add your IQ panel, then Add Association
Make sure to optimize then backup your network in HS4.
Hey, that’s fantastic, thanks for confirming and for the write-up! I haven’t tried HomeSeer myself glad to know it’s a good option for an additional controller!
Sorry to bring back an old thread… I’m considering Surety for my home security needs. I too use homeseer to control my existing smart home devices (lights, coffee machine, etc). I’d like to 1) be able to trigger events from door sensors depending on qolsys armed status 2) trigger events when the qolsys system changes armed status 3) control zwave lights/switched from the qolsys panel 4) go through surety for home monitoring.
There’s an old hardwired ADT system left behind from the prior owner. I need to add lot more window sensors and update/add smoke/CO detectors, flood detectors, etc.
Is this all feasible through Surety and the qolsys panel and sensors they sell?
Edit: I guess the question I’m asking is: Is there an interface in which the Qolsys panel can send sensor information to Homeseer HS4 software?
No, there is not an ability to share sensor data with a third party device/software. Sensor activity data is transmitted to Alarm.com and visible on the panel, but not shared via other radios like Z-wave.
The Qolsys panel functions as a Z-wave controller, and automation would be set up through Alarm.com. You can link Z-wave controllers, but you will not get sensor data that way. You can use Alarm.com rules to perform the actions you are referencing with compatible Z-wave devices and the Qolsys panel.
