Cable would hit the 900Mhz module antenna, so I removed it for the flash.
First timer here. I have upgraded to v1.1401 the back to v1.13 on a locked panel and “yes” the panel did reset what I though was everything, but when I try going into “System Configuration” it still indicates the feature is disabled and to contact technical support.
I thought the upgrade then downgrade was supposed to reset the panel to factory defaults and reset all of the questions so that the panel would be like new out of the box. code 2203 works, but 1561 does not work.
Did I miss something? I do not have a cellular communication chip in the device so cannot have Alarm.com do a reset through the back door.
any help would be appreciated.
It doesn’t work on the vivint panel. Vivint uses a custom firmware variant (which I think may have something to do with it).
You will need to have Q43 reset via airfx backend.
How do I request OTA update for my panel since I bought a bridge partly due to the promise of OTA upgrades? Also, does OTA upgrade the TS1 as well?
If you would like to request an OTA update, and you are a suretyDIY subscriber, email customerservice@suretyDIY.com your intentions along with your Verbal Admin Pass Code for verification purposes. The OTA will cover the TS1 panel as well so long as it is connected to the main panel and it is the same firmware ver. as your main panel.
Hey Tatoohead, I was also USAF AMMO, 20 years. Small world man.
Haha! Get outta here! Don’t tell me your first name is Jack too?! (We’ll probably get yelled at for posting here.)
I.Y.A.A.Y.A.S.
My AF nickname is Jack, short for Jackson. How long have you used the 2gig panel? Looking over your posts, seems like you are pretty involved with the setup. Just converted my Vivint 2gig to alarm.com monitoring, but now want to add more features, like garage door control and home automation. Anyway to PM users on here?
Have been using the GC 2 for a couple years at least. A fellow convert from Giving also.
I don’t believe there’s a PM system on the board, my email is ammo1 (at) wi (dot) rr (dot) com if you wanna shoot the proverbial poop!
I’m using the Chamberlain My Q for the garage. It’s not without its problems, but overall, functions fairly good.
I’m by far not the most knowledgeable about the items that work with 2gig, but I can tell you what worked for me. ???
Surety has a great tech support team. Them, along with the other members here, will definitely be able to answer any questions or solve any problems you might encounter along the way.
Always happy to help out a fellow Ammo Troop too!
tattoohead-email sent
