Agreed. Ryan just posted to the actual firmware update. We have everything here. The instructions are shown third from the top and here.
There is a PDF in the zip file with the instructions.
So Far this is all I have seen in regards to release notes.
Seems for the Frontend:
V1.12 adds support for broadband communication capability via the Go!Bridge (adds dual communication for cellular and WIFI), Portuguese language, minor UI changes, etc. This update is only for CP, TS1 version is 1.10.
And on the Backend:
New Advanced Remote Commands Now Available for 2GIG
Go!Control 2gig_panel
A new firmware release for 2GIG Go!Control Panels will make installation and system maintenance right from your mobile device easier than ever. The new 1.12 firmware delivers more remote capabilities so you can now enjoy:
Quicker Installation
Put the 2GIG panel in Add or Delete Mode directly from the Dealer Website or MobileTech. When the Remote Add or Delete Mode command is sent, the panel will stay in that Mode until you exit, allowing you to continuously add devices without additional steps in-between.
Improved Z-Wave Network Stability
Perform a remote Rediscovery from the Dealer Website or MobileTech to help assure the stability of the mesh network. Run this when you complete an installation or have recently added, removed, or moved devices in the network. Remote Rediscoveries will take approximately 5 minutes and vary depending on the size and complexity of the network.
Long-Term Tracking and System Performance Diagnosis
With 1.12, you now have the ability to request and analyze diagnostic counters of a Z-Wave network.
These new features will help make your installations more efficient and provide an even smoother customer experience.
Hi can u please update my firmware to the new 1.12 via OTA I understand the 15 charge , Thank You
Will this firmware fix the z-wave lighting issue where you can’t tell if your lights are on or off in the app?
No, the Z-Wave lighting issue isn’t a bug. It’s a legal issue. Some a%#holes at Lutron convinced the US patent office that their “idea” to transmit the status change of a light switch via a wireless signal is non-obvious and therefore a patentable invention. Lutron has a patent on doing that and the rest of the world is out of luck. You could always dump your Z-Wave stuff for more expensive Lutron Caseta stuff which is also supported by Alarm.com and then you can see light switch status on the Alarm.com app. Meanwhile I’m hoping my pending patent on alternating steps between my left and right feet when walking in a forward direction will be granted. Wish me luck.
Damn, that sucks! Thanks for the update.
I downloaded the FW and have the update cable but in the zip I don’t see 1.12 for the TS1. Since the Go Control and the TS1 have to have the same firmware to communicate, I have to wait until they have the 1.12 for the TS1 also. Or am I mistaken?
Hi BadPapaBear - the 1.12 update is only for the control panel. The TS1 does not have new firmware at this time and does not have to be on the same version as the control panel, as long as it is at least at (I believe) 1.10. I have updated my control panel to 1.12 and my TS1 continues to work fine on 1.10.
Schweetness, When I first received my TS1 it was 1.9 and my panel was 1.10. They wouldn’t talk to each other until I made them the same FW. At the time, I talked to 2Gig and they said they have to be on the same FW. Maybe 1.10 was a game changer… still makes me a little bit nervous.
I have a TS1 and have updated panel firmware to 1.12
Here is a summary
V1.12 adds support for broadband communication capability via the Go!Bridge (adds dual communication for cellular and internet connectivity), Portuguese language, minor UI changes, etc. Improved backend remote capabilities. This update is only for CP, TS1 firmware version remains 1.10.
Firmware just needs to be on the same base level. So 1.9 TS1 firmware works with 1.9 Panels, 1.9.4 Panels, 1.9.6 Panels, etc.
Alright that makes sense, thanks for the reassurance!
That is going to confuse people.
Firmware 1.12 no longer requires same base level for CP And TS1
TS1 firmware 1.10 works with 1.12 panels
Are there any obvious UI changes or bug fixes with the new firmware?
Unknown regarding bug fixes, but there are a lot of remote back end improvements, minor UI changes, upgrades to the XCVR2 transceiver (I think then “clean screen” is different), additional programming Q’s…
v1.13 is out, includes update for ts1 (same build)
Has anyone seen release notes?
The release notes are available here. We’ll have V1.13 firmware available on our website by tomorrow at the latest.
Thanks Amanda, very interesting. Now questions and comments:
- Now that it supports the Linear Garage Door Opener, does this mean the Linear will now work with ADC as an alternative to the Liftmaster? It does seem nice to bring that integration into the panel instead of requiring a third party.
- Nice to have another supported wireless siren - I’ve read that others have used the $30 one from Lowes, but the Nexia is louder
- Any plans from Surety to support Uplink in addition to ADC? I don’t know much about Uplink except for their abysmal app review score, but would be interested to see how the cost compares.
- Love the new voice descriptors. Finally can announce those “MAN CAVE” sensors.
