Firmware Release Information - GC3
2GIG GC3/e Panel Firmware Version 3.2.4
There is a known issue which can cause the panel to mishandle Interior Follower zone types during entry delay. If you use motion detectors in areas between your entry point and the panel, do not use this update, or program motion detectors as zone type (10) Interior with Delay.
New Features:
Question 72 (Q72) – Config change acknowledgement question added.
  • Q72 – Config change acknowledgement
    • Options: Enabled or Disabled (Default: Enabled)
      • Enabled – The panel will announce the panel status when the panel powers up, reboots, or exits programming. (Panel
        behavior will not change from previous firmware versions.)
      • Disabled – This option will suppress the annunciation of the panel status when the panel powers up, reboots, or exits programming.
Note 1:
When changes are made to the customized panel functions thru the Alarm.com portal including but not limited to items related to
programming, sensors, and the addition, deletion or modification to users, the GC3/e panel will currently announce its current status.
Example: “System disarmed, ready to arm.” Changing programing to Q72 to “Disabled” status will suppress this annunciation from the
panel.
Note 2:
The change to Question 72 will only affect the annunciation of the status thu the panel, as described above. Question 72 will not affect any
other annunciations of the GC3/e panels.
Enhancements and Defect Resolutions:
  • Resolved Periodic test/Auto phone test failing to send a test signal when Question 33 is set to the default value
    of 30 days.
  • Resolved issues regarding OTA.
