Can SURETY MONITOR the subject system configuration?
Thanks for reaching out! Your DSC PC1616 panel is compatible with Surety, but the BAT-Connect communicator isn’t. Surety provides monitoring through Alarm.com cellular communicators only, so the BAT-Connect would need to be replaced.
For your PC1616, you’d replace it with the Alarm.com System Enhancement Module (SEM300) for DSC PowerSeries:
A few things to know:
- Firmware: the SEM300 requires a PC1616 running firmware version 4.2 or later. You can check this by entering [*][8][Installer Code][900] on your keypad. The panel version will be displayed.
- Keep your equipment: your existing sensors and keypads stay in place. Only the communicator is replaced.
- Installer code: you’ll need your panel’s installer code to complete the setup.
Once the SEM300 is installed, you can choose a plan at Smart Home Automation & Security Plans | Surety and set up your account through our System Manager.
Please let us know if there is anything else we can do to help.
Can I keep my existing DSC 1616 security monitor which includes alarm.com monitoring, and add surety video only monitoring. If I buy SVR and 4 cameras from Surety?. Can the video be self monitored through same alarm.com account as security monitored.
Thanks for reaching out! Your DSC PC1616 can work with Surety, but there’s one thing to know about your current communicator.
Your BAT-Connect communicator
The BAT-Connect is an Alula cellular communicator, which isn’t compatible with Alarm.com. To have your security system and cameras together in one Alarm.com account with Surety, you’d replace it with the Alarm.com System Enhancement Module (SEM300) for DSC PowerSeries:
- Firmware: the SEM300 requires your PC1616 to be on firmware version 4.2 or later. You can check by entering [*][8][Installer Code][900] on your keypad.
- Installer code: you’ll need your panel’s installer code to set up the SEM300.
- Your equipment: your existing sensors and keypads stay in place.
One account for your alarm and cameras
Our Surety Protect plan includes your security system and up to 4 cameras in the same Alarm.com account, so you can control your alarm and view your cameras in one app.
- Self-monitored: $21/month. You’ll get alerts for your alarm and cameras, plus recorded clips and live video anytime.
- With 24/7 professional monitoring: $26/month. Your security system is professionally monitored, and your cameras stay self-monitored.
Plan details: Smart Home Automation & Security Plans | Surety
Getting started
- Purchase the SEM300, your SVR and your cameras.
- Replace the BAT-Connect with the SEM300.
- Purchase the Surety Protect plan and create your Surety login during checkout.
- Go to our System Manager to create your Alarm.com account and connect your system: My Account - Surety Home
- Add your SVR and cameras to your Alarm.com account.
I do not have installer code. If installer doesn’t surrender, what would you recommend to maintain wired system.
Who is your current installer? If you have ADT or an ADT company, you can try using installer code 6321.
To test the code, enter *8 + Installer code. If nothing happens then it is the wrong code. If you see the arming light turn on, then you are in programming.
If not, then the next option would be to replace the panel. You could try finding a DSC panel that way you can reuse all your keypads but the PC1616, PC1832, and PC1864 have been discontinued. You could use an IQ Panel 5 with a PowerG takeover moduel. To give better details on this, I would need to know how many zones you have and how many keypads and if you have anything special on your panel. A picture could help.
How about IQ Pro? Would it work with old DSC 5501 keypads? Or would I need new keypads as well?
Unfortunately, your existing DSC PowerSeries keypads aren’t compatible with the IQ Pro. Here are the compatible keypad options for both the IQ Pro and the IQ Panel 5 with the hardwire takeover module.
Option 1: IQ Pro
The IQ Pro works with DSC PowerSeries Neo keypads and Qolsys IQ Remote touchscreens:
| Keypad type | Model |
| Touchscreen keypad | IQ Remote |
| Touchscreen keypad (PowerG) | IQ Remote PG |
| LCD keypad | HS2LCD |
| LCD keypad with proximity reader | HS2LCDP |
| LCD keypad with PowerG transceiver | HS2LCDRF9 |
| LCD keypad with PowerG transceiver and proximity reader | HS2LCDRFP9 |
| LCD wire-free keypad | HS2LCDWF9 |
| LCD wire-free keypad with proximity reader | HS2LCDWFP9 |
For the PowerG models, choose the version ending in 9, the 912–919 MHz version used in the U.S. You can find this list in the IQ Pro Installation Manual, Table 4 on page 8: https://suretyhome.com/wp-content/uploads/IQ-Pro-Installation-Manual.pdf
Option 2: IQ Panel 5 with the IQ Hardwire PowerG module
The IQ Panel 5 is the main panel and keypad. The IQ Hardwire PowerG (PG9WLSHW8) takes over your existing wired zones and connects them to the IQ Panel 5 wirelessly.
- IQ Panel 5: IQ Panel 5 - Qolsys - Surety
- IQ Hardwire PowerG: IQ Hardwire PowerG - Qolsys PG9WLSHW8 - Surety
Your DSC PowerSeries keypads won’t work with this setup either, but you can wire up to four DSC PowerSeries Neo keypads to the IQ Hardwire PowerG module (module firmware v1.1 or later). Compatible models:
- HS2ICN
- HS2ICNP
- HS2LCD
- HS2LCDP
- HS2LCDENG
These keypads can arm and disarm the system, show zone and partition status, and use the function keys. They work alongside the IQ Panel 5, which stays your main panel for programming and settings. You can find more about the IQ Hardwire PowerG, including its installation manual, here: IQ Hardwire PowerG (PG9WLSHW8)
You can also add wireless PowerG keypads that connect directly to the IQ Panel 5:
- IQ Remote PowerG secondary touchscreen (IQR-PG): IQ Remote PowerG Secondary Touchscreen - Qolsys IQR-PG - Surety
- IQ Keypad PowerG (IQKP-PRX-915): IQ Keypad - Qolsys IQKP-PRX-915 | IQKP-915 - Surety
