Since daylight savings time my panel has been off which has caused my automation rules to fire at the incorrect times. I have tried to save the time at the panel but it appears to keep switching to the incorrect time. What can I do?
Happy to assist! Commands have been sent to push the correct time to your panel and the time appears to be correct on this end, can you confirm?
If the time is still off, what time does the panel currently say? In which direction is the time off?
If the time is off still you will want to power down the panel completely transformer first then internal battery. Wait about five minutes then plug the battery back in, followed by transformer. Once it boots up, is the time correct?
