I have a CSVR2000P displaying 4 of my cameras continuously and every once in a while (every week or two) one of the camera feeds just get stuck and stops updating. It’s completely different than cameras not updating due to network sync issues (which shows up as darkened and with a blue “i” logo) but it still looks completely fine, it just stops updating. I normally only notice because it’s still night or day in one camera and the rest are different…
it’s actually still recording and I can watch the video from the SVR page on the alarm.com website, it’s simply just a display issue on the CSVR GUI. I can easy “fix” it by double clicking on the video feed to make it full screen and then, double clicking again to make it “normal”. it’s not specific to a camera as it’s happened on multiple feeds.
Thanks for letting us know it happened again. Which camera is the tile frozen on this time, and which cameras has it happened with in the past?
If it’s been the Garden or Backyard camera, the cause is likely signal strength. Both of those cameras connect through ADC-W110 PoE to Wi-Fi bridges, and they’re currently showing a normalized signal strength of about 51%-52%. At that level, a brief drop in the Wi-Fi connection can cause the live video tile to freeze, even though the camera keeps recording to the CSVR.
Here are a few ways to improve the signal for those bridges:
Move the W110 closer to your router or access point, with as few walls and obstructions between them as possible. Brick, concrete, stucco and metal can weaken the signal significantly.
Add a Wi-Fi extender or mesh access point closer to the W110s.
The W110 only connects on 2.4 GHz. If you have a dual-band router, giving the 2.4 GHz and 5 GHz bands separate network names (SSIDs) can help keep the bridges on a stable connection.
If you have a mesh system, try keeping the W110s connected to the access point closest to them, since mesh systems can move devices between access points.
Make sure your router’s firmware is up to date.
Here are a couple of our forum guides with more details:
Let us know which camera is affected, and if it is one of these two, whether the freezing improves after strengthening the signal.
