Hi i was wondering if you can help me adjust settings or swap out or turn off my motion detectors (if needed) because Surety monitoring center calls me each time I arm the panel at my house.
They call because motion detectors are triggered when no one is home except my cat and small dog.
I thought motion detectors only detect motion with a weight minimum.
How could I fix this situation, do i need to change motion sensors or adjust settings?
Yes, to clarify, whenever you tap the arming option in the app you can then select “Bypass Specific Sensors” allowing you to choose which sensors to bypass.
You can also change the programming for a specific problem motion detector if you know it will always cause a problem. It can be set to sensor group 25 which is a no response type zone. This means it can be used for notification purposes in Alarm.com but it would never generate an alarm regardless of arming state.
If you may want to use that motion detector as an alartm sensor sometimes, just bypassing it when arming when necessary can be done while arming at the panel or in the app or website.
