Do you see the option available in the Alarm.com Website? How long ago did this occur?
is there a way to set a auto (heat+cool) threshold based schedule? I am currently using Honeywell T6 Pro which doe support auto mode from panel.
There is not a specific Auto threshold that can be set. All scheduling options available through Alarm.com are located on the Alarm.com website. Navigate to the Thermostat Card then click on Schedules. More information on setting up schedules can be found below.
It started happening a few weeks ago. I see it on alarm.com as well as the panel, but not on the iPhone app.
The schedule tab only provided options to set heat or cool targets, not auto heat/cool targets. It would be incredibly useful to have a schedule for auto mode. Any workaround to do this? Asking cause eachtime I arm away/disarm or run sleep scene, I am having to set the auto targets all over again. Usually, if I am in only heat or cool modes, the away/home/sleep scenes adjust as per schedule or rules. But, it does not seem to be happening with auto mode.
Navigate to the App store and make sure you have the most recent version downloaded. Then login to the app, navigate to About and check the Alarm.com build number for you app, what is it?
Correct. The schedule is for Heat or Cool modes only, a schedule for Auto mode is not available.
